15 years agoDividing clock source - PLL
Hello, I was trying to reduce clock frequency of Cyclone II i Quartus form 50MHz to 5 Hz. I heard, this need to be done by megawizard, SoPC builder and then PLL. But the thing is, that I canno...
15 years ago5 Hz is much too slow for a PLL, and as you can see, the minimum output of a PLL is 10MHz.
What you need to do is clock your 5Hz logic at 50MHz, and generate a clock enable that makes the circuit appear to run at 5Hz.
