Discrete RSU User Logic
I want to do an discrete RSU with UART interface. I wrote the UART, RAM and on-chip memory in VHDL but how can I write dualboot and user logic of RSU. There is an atom for RSU implementation published by Intel but all my works are in VHDL, so how can I convert this into VHDL or I can run this on VHDL based project?
fiftyfivenm_rublock <rublock_name> ( .clk(<clock source>), .shiftnld(<shiftnld source>), .captnupdt(<captnupdt source>), .regin(<regin input source from the core>), .rsttimer(<input signal to reset the watchdog timer>), .rconfig(<input signal to initiate configuration>), .regout(<data output destination to core>) ); defparam <rublock_name>.sim_init_config = <initial configuration for simulation only>; defparam <rublock_name>.sim_init_watchdog_value = <initial watchdog value for simulation only>; defparam <rublock_name>.sim_init_config = <initial status register value for simulation only>;
- JohnT_Altera
- JohnT_Altera
The fallback will automatically happen when the configuration failed. In order to update the CFM then you will need to use the On Chip Flash IP.
You may refer to https://fpgacloud.intel.com/devstore/platform/17.1std.1/Standard/i2c-remote-system-update-example/ on how to implement RSU in Max 10.
- RVadl2
@JohnT_Intel Hi, I am following the example that you mentioned i.e
Can you point me to Altera example projects that contain the source files(c files) of nios_platform.pof and source files of RSU.sof.
Thanks in Advance.
- JohnT_Altera
I would recommend you to generate the Dual Configuration IP in VHDL which will be more easier to use rather than the ATOM module.
- JohnT_Altera
Attach is the IP generated. You can observed that inside the "RU" folder, where RU_inst.vhd is calling RU_inst.v file.
- jozephka99
Contributor
Thank you for your reply @JohnT_Intel. I don't know either the signal informations. I just wanted to perform discrete RSU. Also I'm already started to use dual config IP. So far, I'm able to set config_sel and reconfig the device in either CFM0 or CFM1/2. I think this is enough for RSU. But if you know how to do error checking and fallback situations it is also useful for me. But the main issue that I working on now how I can write the .rpd file into CFM sectors. I can use the on-chip flash IP but I don't know the form of data that I write into CFM. Can I write the data as well as in the .rpd file? In AN741 the data's MSB and LSB was swapped, do I have to swap too? I'll use UART interface, the data came as bytes. I'm planning the write the data into RAM first. When the data came, then I'll write it to CFMs. Also for testing I want to initialize the RAM for not doing the data sending stuff for now. So anything you know about my situation will be helpful.
- JohnT_Altera
May I know what signals types and lengths information that do you need? We only have the port connection information and you should be able to invoke connect it to VHDL.
- JohnT_Altera
Unfortunately we do not have the timing information on this. You can only get the timing information based on the TimeQuest report.
- jozephka99
Contributor
Timing information? I don't want to know timing information. Where did you get this idea from? I just want to know how I implement the rublock to VHDL or any other way to do discrete RSU.
- JohnT_Altera
You will need to instantiate the IP as a verilog module before you are able to instantiate the the verilog module in VHDL. https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11162011_444.html
- jozephka99
Contributor
I try this but I cannot do that because for creating a component we need the signals types and lengths and I don't know these signals' informations just their names. Addition to this I'm still very shocked about how Intel's documentations in discrete RSU is realy bad even there is no documentation and when I ask about this topic this forum didn't tell me anything except I already know.
- saconnex
Exactly, I am trying to make discrete RSU logic for months, as an intern in a company. I am not sure is this a suitable project for an intern or not but I do have hard times. AN741 documentation is just for Nios II, just the video mention discrete logic yet some sentences. I will use On-Chip Flash IP Core, and UART core. I should design the state machine myself. The on-chip IP user guide is well-documented but UART is not. I could not find how to access the registers inside the UART core. By the way, I will not use Dual-Configuration IP logic, since I will delete the CFM first and put the new image to CFM. That's why I think I do not need to trigger it since it automatically uses the image that I put in CFM. Am I wrong? Thanks in advance..
