Drop-in replacement for EPCS64SI16N
I am looking for a replacement for the EPCS64SI16N (EOL). The EPCQ64ASI16N seems to be quite similar, but we need to be sure that they are a drop-in replacement and functionally the same. So, the EMS producing for our customer should ideally be able to use the replacement part just the same as the obsolete one.
The Config Device interfaces with the EP4CE55F23C6N FPGA.
Do you know if that is possible?
Thanks!
Korbinian
- kw_arrow
Hi Farabi,
Thank you for your detailed answer! I have shared this with the customer and am awaiting feedback.
Kind regards
Korbinian- Farabi_Altera
Hi Korbinian,
Have you received customer feedback?
regards,
Farabi - Farabi_Altera
Hi Korbinian,
Ok noted. I will wait for customer feedback.
regards,
Farabi
- Farabi_Altera
Hello, do you have further question?
- Farabi_Altera
Hi Korbinian,
Good question — this is a common migration scenario. Let me walk you through the key compatibility points for your EPCS64SI16N → EPCQ64A (EPCQ64ASI16N) transition with the EP4CE55F23C6N.Package / Pin Compatibility
Pin-to-pin compatibility means the power pins, ground pins, and dedicated pins are at the same locations across devices, and drop-in (vertical migration) compatibility additionally requires that the devices operate at the same voltage level. General · General Both the EPCS64SI16N and EPCQ64ASI16N are 16-pin SOIC packages, so the footprint is the same. For a 16-pin SOIC package, you can migrate vertically from an EPCQ64 device to EPCQ128, EPCQ256, or EPCQ512/A device Config/RSU — and the same SOIC-16 footprint is shared across the EPCS/EPCQ family, so the PCB footprint is compatible.VCCIO Voltage Requirement — Important!
When using an EPCQ or EPCQA quad-serial configuration device for AS configuration, you cannot connect VCCIO of I/O bank 1 to 2.5 V in Cyclone IV devices, because the minimum VOH of the FPGA is insufficient for driving EPCQ or EPCQA input pins. You must use 3.0 V or 3.3 V for Bank 1 VCCIO when AS configuration with EPCQ or EPCQA devices is used. Cyclone 10 · Config/RSU If your current design already runs Bank 1 at 3.0 V or 3.3 V (which is typical for EPCS-based designs), you're fine. If it's at 2.5 V, that needs to be addressed.Programming File Compatibility
This is the most important software-side consideration. The programming file compatibility for EPCS and EPCQ to EPCQA devices is as follows for Legacy FPGA devices (which includes Cyclone IV, as it is not a Cyclone V/Arria V/Stratix V device):- EPCS, 64 Mb and below → .pof/.jic/.rpd/.jam/.jbc: Compatible with EPCQA (any ID check setting)
- EPCS, 64 Mb and below → .svf: Compatible with EPCQA
- EPCQ → .pof/.jic/.rpd/.jam/.jbc: Compatible with EPCQA only if the "Disable EPCS/EPCQ ID check" option is turned ON
Since you're coming from an EPCS64 (not an EPCQ), and Cyclone IV is a legacy device family, your existing .pof/.jic/.rpd/.jam/.jbc programming files should be compatible with the EPCQ64A without needing to change the ID check setting.IP Core Compatibility
If your design uses any in-system programming or remote update IP cores, note that compatibility varies by IP: the Remote Update IP core is compatible when migrating from EPCS to EPCQ-A devices. Arria 10 · Config/RSU The Serial Flash Controller IP compatibility is listed as Yes/No (conditional) for EPCS to EPCQ-A migration Arria 10 · Config/RSU , so you'd want to verify that specific IP's configuration if you use it.Cyclone IV GX Speed Grade Note (not applicable here, but FYI)
Cyclone IV GX supports ASI only with -6 and -7 speed grade devices — not all speed grades support ASI. Cyclone IV · Config/RSU Since you're using a Cyclone IV E (EP4CE55), this restriction doesn't apply to you.Summary
For your EP4CE55F23C6N + EPCS64SI16N design migrating to EPCQ64ASI16N:- ✅ Same 16-pin SOIC footprint — PCB drop-in compatible
- ✅ Programming files (.pof/.jic/.rpd/.jam/.jbc) are compatible for legacy FPGA devices with EPCS 64 Mb source
- ✅ EPCQ64A uses NOR flash, same as EPCS — functionally equivalent for AS configuration
- ⚠️ Verify Bank 1 VCCIO is 3.0 V or 3.3 V (not 2.5 V)
- ⚠️ If you use any ASMI/SFL IP in-system, verify IP compatibility for your specific IP core
Overall this is a well-supported migration path and your EMS should be able to use the EPCQ64ASI16N as a drop-in replacement, provided the VCCIO check passes. Let me know if you have further questions!
