16 years agoDesign portability on a cyclone
Good morning,
I've got a HDL design which run in RTL simulation. This design run in gate level simulation with time modelisation on a stratix II or an arria II. Howerver, it doesn't work on a cyclone (II or III) FPGA. I don't know what to do ! It's the first time for me that a design work on RTL simulation, on gate level simulation for several device but not on a Cyclone II/III. For information here is the result of the ressource utilization on stratix II :Combinational ALUTs 5,491 / 72,768 ( 8 % )
Dedicated logic registers 4,037 / 72,768 ( 6 % )
Combinational ALUT usage by number of inputs
-- 7 input functions 29
-- 6 input functions 1400
-- 5 input functions 625
-- 4 input functions 600
-- <=3 input functions 2837
Combinational ALUTs by mode
-- normal mode 3957
-- extended LUT mode 29
-- arithmetic mode 1388
-- shared arithmetic mode 117
Logic utilization 7,961 / 72,768 ( 11 % )
-- Difficulty Clustering Design Low
-- Combinational ALUT/register pairs used in final Placement 7168
-- Combinational with no register 3131
-- Register only 1677
-- Combinational with a register 2360
-- Estimated pairs recoverable by pairing ALUTs and registers as design grows -260
-- Estimated Combinational ALUT/register pairs unavailable 1053
-- Unavailable due to unpartnered 7 LUTs 18
-- Unavailable due to unpartnered 6 LUTs 886
-- Unavailable due to unpartnered 5 LUTs 27
-- Unavailable due to LAB-wide signal conflicts 99
-- Unavailable due to LAB input limits 23
Total registers* 4,037 / 75,850 ( 5 % )
-- Dedicated logic registers 4,037 / 72,768 ( 6 % )
-- I/O registers 0 / 3,082 ( 0 % )
ALMs: partially or completely used 4,263 / 36,384 ( 12 % )
Total LABs: partially or completely used 585 / 4,548 ( 13 % )
User inserted logic elements 0
Virtual pins 0
I/O pins 168 / 535 ( 31 % )
-- Clock pins 12 / 16 ( 75 % )
Global signals 2
M512s 0 / 488 ( 0 % )
M4Ks 16 / 408 ( 4 % )
M-RAMs 1 / 4 ( 25 % )
Total block memory bits 223,096 / 4,520,448 ( 5 % )
Total block memory implementation bits 663,552 / 4,520,448 ( 15 % )
DSP block 9-bit elements 4 / 384 ( 1 % )
PLLs 0 / 6 ( 0 % )
Global clocks 2 / 16 ( 13 % )
Regional clocks 0 / 32 ( 0 % )
SERDES transmitters 0 / 118 ( 0 % )
SERDES receivers 0 / 118 ( 0 % )
JTAGs 0 / 1 ( 0 % )
ASMI blocks 0 / 1 ( 0 % )
CRC blocks 0 / 1 ( 0 % )
Remote update blocks 0 / 1 ( 0 % )
Average interconnect usage (total/H/V) 2% / 2% / 2%
Peak interconnect usage (total/H/V) 27% / 27% / 26%
Maximum fan-out node CLK~clkctrl
Maximum fan-out 4076
Does anybody got ideas ?19 Replies
--- Quote Start --- Neither do I. Megafunction inference is sometimes mysterious... In this case, the constant type seems to be the problem. It's a kind of Quartus design compiler bug in my opinion. --- Quote End --- Hi FvM, I agree with you, because for other device families it seems to work fine. Kind regards GPK - Altera_Forum
--- Quote Start --- However I don't understand why it work. --- Quote End --- Neither do I. Megafunction inference is sometimes mysterious... In this case, the constant type seems to be the problem. It's a kind of Quartus design compiler bug in my opinion. - Altera_Forum
OK !
It works properly you was right. I have made a mistake on how to modifie a file wich is include in a SOPC. Thank you VERY VERY much - Altera_Forum
I tried. Thank you. However I don't understand why it work.
Now I manage to make the gate level simulation with propagation time but : it doesn't work on hardware? I never saw that ... What can I do ? - Altera_Forum
I found, that there's exactly one dangerous warning in the Cyclone III report:
--- Quote Start --- Warning: Synthesized away the following node(s): Warning: Synthesized away the following RAM node(s): Warning (14320): Synthesized away node "FDCT:U_FDCT|MDCT:U_MDCT|ROME:\G_ROM_ST1:0:U1_ROME|altsyncram:Mux11_rtl_15|altsyncram_0hv:auto_generated|ram_block1a0" --- Quote End --- It's originated from an instance of rome.vhd. By changing the table definion in rome.vhd from
toconstant rom : ROM_TYPE :=
the above warning vanished and the ROM implementation was changed from Mux11_rtl_15 to rom_rtl_15. I didn't set up the ModelSim simulation, but I hope, the problem can be solved this way.signal rom : ROM_TYPE := - Altera_Forum
--- Quote Start --- Hi, I already tried with the new quartus version 9.1. However it doesn't work. If you have an idea it would be great. In anyway, thank you. --- Quote End --- Hi actris, which versions did you try up to know ? 9.1 and 9.0 ? Maybe you should try an older one. I will try to setup your project in my environment, but this take some time. Kind regards GPK - Altera_Forum
In anyway, thank you. - Altera_Forum
--- Quote Start --- But I can't evaluate where the problem come from because I am in gate level simulation. --- Quote End --- You should be still able to assign the nets to original design entities and try to determine what's the 'X' source in your design. - Altera_Forum
--- Quote Start --- Yes data_out ='X' But I can't evaluate where the problem come from because I am in gate level simulation. What can I do ? --- Quote End --- Hi, it looks for me as an synthesis issue, because the synthesis engine are different for the FPGA families. Can you try an older or newer Quartus version ? Kind regards GPK - Altera_Forum
Yes
