delay for a Sinusoid
I am using an FPGA kit for controlling my power electronic converter. To implement the PLL, I have to give a delay of .005s to a signal whose frequency may range from 20 to 70 Hz. The input is given from a 12 bit ADC. My sampling frequency is 20kHz and I am using a Cyclone device.
How do I implement the logic?6 Replies
According to your original post, you won't require taps with your FIFO. In my example cnt_5ms is simply an integer constant, defined above in the code. But you can calculate it from clock frequency and time delay in the code, e.g.
You may want to read the respective Verilog syntax from a manual or text book.CONSTANT CLK_PWM_kHz : INTEGER = 40; CONSTANT DELAY_ms5 : INTEGER = 5; CONSTANT CNT_5MS : INTEGER = CLK_PWM_kHz*DELAY_ms5; - Altera_Forum
Hello FvM,
Thank you very much for your reply.In the code you had mentioned earlier, you had given tap distance in terms of time.But in MegaWizard Plug-in manager, how can I give that? My .v file corresponding to altshift_taps MegaFunction is given below. // synopsys translate_off `timescale 1 ps / 1 ps // synopsys translate_on module altshift_taps3 ( clock, shiftin, shiftout, taps); input clock; input [11:0] shiftin; output [11:0] shiftout; output [143:0] taps; wire [143:0] sub_wire0; wire [11:0] sub_wire1; wire [143:0] taps = sub_wire0[143:0]; wire [11:0] shiftout = sub_wire1[11:0]; altshift_taps altshift_taps_component ( .clock (clock), .shiftin (shiftin), .taps (sub_wire0), .shiftout (sub_wire1), .aclr (1'b0), .clken (1'b1)); defparam altshift_taps_component.lpm_hint = "RAM_BLOCK_TYPE=M512", altshift_taps_component.lpm_type = "altshift_taps", altshift_taps_component.number_of_taps = 12, altshift_taps_component.tap_distance = 100, altshift_taps_component.width = 12; Can I change this code to get tap distance mentioned in terms of time? - Altera_Forum
My example is for 16 bit data. Just set width to 12.
The input is given from a 12 bit ADC.Can you please suggest me a solution for this?
For either digitized analog or digital signal, you can use altshift_taps MegaFunction, as in the below example.
-- CONSTANT CNT_5MS : INTEGER := 500; in_beta_delay : altshift_taps GENERIC MAP ( lpm_type => "altshift_taps", number_of_taps => 1, tap_distance => CNT_5MS, width => 16 ) PORT MAP ( clken => phase_pwm_s, clock => clk40, shiftin => u_Nalpha, shiftout => U_Nbeta ); - Altera_Forum
You don't state whether the input is a digital signal, but let's assume it is
(i.e., a square-wave at FPGA-compatible levels) - Instantiate a 100-bit shift-register clocked at 20KHz. Your signal is the input, and the output is the same, delayed by 50uSec*100= .005s Wade Hassler
