17 years agodelay for a Sinusoid
I am using an FPGA kit for controlling my power electronic converter. To implement the PLL, I have to give a delay of .005s to a signal whose frequency may range from 20 to 70 Hz. The input is given ...
17 years agoAccording to your original post, you won't require taps with your FIFO. In my example cnt_5ms is simply an integer constant, defined above in the code. But you can calculate it from clock frequency and time delay in the code, e.g.
CONSTANT CLK_PWM_kHz : INTEGER = 40;
CONSTANT DELAY_ms5 : INTEGER = 5;
CONSTANT CNT_5MS : INTEGER = CLK_PWM_kHz*DELAY_ms5; You may want to read the respective Verilog syntax from a manual or text book.
