17 years agodelay for a Sinusoid
I am using an FPGA kit for controlling my power electronic converter. To implement the PLL, I have to give a delay of .005s to a signal whose frequency may range from 20 to 70 Hz. The input is given ...
17 years agoFor either digitized analog or digital signal, you can use altshift_taps MegaFunction, as in the below example.
-- CONSTANT CNT_5MS : INTEGER := 500;
in_beta_delay : altshift_taps
GENERIC MAP (
lpm_type => "altshift_taps",
number_of_taps => 1,
tap_distance => CNT_5MS,
width => 16
PORT MAP (
clken => phase_pwm_s,
clock => clk40,
shiftin => u_Nalpha,
shiftout => U_Nbeta
