13 years ago
DDR2 hard memory interface in ARRIA V
Its the first time I'm using ddr2 hard memory for altera .
can somebody explain the hard memory ddr2 interface?
what signals should I drive in : AFI I/Os ? what do I need it for?
afi_clk
afi_half_clk
afi_reset_n
what signals should I drive in :calibration/command I/Os
mp_cmd_clk_0_clk
mp_cmd_reset_n_0_reset_n
mp_rfifo_clk_0_clk
mp_rfifo_reset_n_0_reset_n
mp_wfifo_clk_0_clk
mp_wfifo_reset_n_0_reset_n
local_init_done
local_cal_success
local_cal_fail
local_refresh_req
local_refresh_chip
local_refresh_ack
oct_rzqin
Many thanks
    same here, any progress guys?
    In my Arria V Kit, the local_init_done never gets asserted :( ... What I've tried?
    - I was told that HMI is disabled by default for Arria V ES http://www.altera.com/support/kdb/solutions/rd01302013_805.html
    I asked the local support to enable it, they advised me to put some option to turn on the HMI, into quartus.ini file but no help
    - Compiled with the latest 13.0, still ... doesn't work.
    If there's any workaround/issues, guys please post it, you can greatly save others' time!
    Jeff
    hello,
    I have tried to run model sim for 135500uS , but my simulation is very slow. i am using model sim altera 12.1 sp1.
    It takes 10min to run this design example for 100usec. it will take me 9 days to run it for 135msec :-).
    Do you know a way how to speed up the simulation ? ??
    thanks
    Is it true that HMI interface is not yet supported in Quartus for Arria V and wouldn't be until 12.2 ???
    I am not sure about this but maybe someone could confirm.
    I was also having problems trying to get the Arria V Hard Memory Interface to work. Everything built and compiled OK and the timing looked reasonable but on the actual board the DDR would not calibrate and start up. I tried reducing the clock speed [was 400MHz] down to something far less critical but still no luck.
    Last September I was at a trade show where Altera had a booth so I went to see if anyone could help me. I was told that actually the HMI interface is not yet supported in Quartus for Arria V and wouldn't be until 12.2
    We have had parts now for more than 1 year [ES] but still I am confused as to whether or not we can use this function especially as it APPEARS to work in QSYS..... so far I have had little response direct from Altera.
    Can you try simulate longer to see when does the local_init_done is complete? For my simulation it took about 135500uS.
    Hi
    I fixed it, but now I have different problem. the ddr2_example_design simulation doesn't work well.
    I implemented a Hard memory interface (ddr2) for ARRIA V in the megawizard. And I wanted to activate the example design.
    I run ddr2_example_design example design exactly as described in README.txt file
    - open the Quartus project "generate_sim_example_design.qpf" and select Tools -> Tcl Scripts... -> generate_sim_vhdl_example_design.tcl and click "Run".The generated files will be found in the subdirectory "vhdl".
    - To simulate the example design using Modelsim AE/SE:
    1. Move into the directory ./verilog/mentor or ./vhdl/mentor
    2. Start Modelsim and run the "run.do" script: in Modelsim, enter "do run.do".
    In the Wave I don't see any action in the ddr2 signals(dq,dqs) its always in tri-state.
    Attached the Wave screenshot.
    It sounds like it could not find the Altera and/or Arria V libraries. Or not all of the libraries are compiled. Try look into msim_setup.tcl to see if all the path to the Altera files are setup properly, if not, you could hard-code it to your exact path and run again.
    Many thanks for your help. I've created a ddr2 ip with megawizard. like you said, it generate an example "ddr2_example_design".
    I run the <vhdl/verilog>.tcl script , the project was compailed and I can see Waves.
    some of the signals are RED (unknown state) : init_done,cal_success,cal_fail,status_fail...
    in the model sim transcript window I see an error :ERROR: Invalid arc in, fsm:AVL_FSM, state:AVL_IDLE
    # Instance: ddr2_example_sim.e0.if0.p0.ddr2_example_sim_e0_if0_p0_ddr2_example_sim_e0_if0_p0_acv_hard_memphy_umemphy_arriav_mem_phy_hphy_inst_6080.inst.<protected>.<protected>
    # Time: 17867500
    # ERROR: Invalid arc in, fsm:AVL_FSM, state:AVL_IDLE
    # Time: 17880000
    Do you know what is this error?
    Any name with the AFI_ is the Avalon Interface from Altera, you can view it as a generic bus. The width of the bus varies with the speed / width you are running on the DDR2/3 interface. All that is configured for you thru MegaWizard (I am using the soft-core instead so maybe there's some difference). I suggest running the complete example design (can be conveniently generated by open the project file, and run the <vhdl/verilog>.tcl script) to visually help understand how the bus works.
    Here are some links that maybe helpful to you:
    Section 9 – MegaWizard Plug-In Manager Flow of the following: http://www.altera.com/literature/hb/external-memory/emi_plan.pdf
    For an overview read this section: http://www.altera.com/literature/hb/external-memory/emi_intro.pdf
    There is also a Stratix III/IV UniPHY tutorial: http://www.altera.com/literature/hb/external-memory/emi_tut_qdr.pdf
    Here is all the documentation on the External Memory Interface Handbook: http://www.altera.com/literature/hb/external-memory/emi.pdf
    Hope this helps
