13 years agoDDR2 hard memory interface in ARRIA V
Hello, Its the first time I'm using ddr2 hard memory for altera . can somebody explain the hard memory ddr2 interface? what signals should I drive in : AFI I/Os ? what do I need it for? afi...
13 years agoIt sounds like it could not find the Altera and/or Arria V libraries. Or not all of the libraries are compiled. Try look into msim_setup.tcl to see if all the path to the Altera files are setup properly, if not, you could hard-code it to your exact path and run again.
