13 years agoDDR2 hard memory interface in ARRIA V
Hello, Its the first time I'm using ddr2 hard memory for altera . can somebody explain the hard memory ddr2 interface? what signals should I drive in : AFI I/Os ? what do I need it for? afi...
13 years agoAny name with the AFI_ is the Avalon Interface from Altera, you can view it as a generic bus. The width of the bus varies with the speed / width you are running on the DDR2/3 interface. All that is configured for you thru MegaWizard (I am using the soft-core instead so maybe there's some difference). I suggest running the complete example design (can be conveniently generated by open the project file, and run the <vhdl/verilog>.tcl script) to visually help understand how the bus works.
Here are some links that maybe helpful to you: Section 9 – MegaWizard Plug-In Manager Flow of the following: http://www.altera.com/literature/hb/external-memory/emi_plan.pdf For an overview read this section: http://www.altera.com/literature/hb/external-memory/emi_intro.pdf There is also a Stratix III/IV UniPHY tutorial: http://www.altera.com/literature/hb/external-memory/emi_tut_qdr.pdf Here is all the documentation on the External Memory Interface Handbook: http://www.altera.com/literature/hb/external-memory/emi.pdf Hope this helps
