13 years agoDDR2 hard memory interface in ARRIA V
Hello, Its the first time I'm using ddr2 hard memory for altera . can somebody explain the hard memory ddr2 interface? what signals should I drive in : AFI I/Os ? what do I need it for? afi...
13 years agoHi,
Many thanks for your help. I've created a ddr2 ip with megawizard. like you said, it generate an example "ddr2_example_design". I run the <vhdl/verilog>.tcl script , the project was compailed and I can see Waves. some of the signals are RED (unknown state) : init_done,cal_success,cal_fail,status_fail... in the model sim transcript window I see an error :ERROR: Invalid arc in, fsm:AVL_FSM, state:AVL_IDLE # Instance: ddr2_example_sim.e0.if0.p0.ddr2_example_sim_e0_if0_p0_ddr2_example_sim_e0_if0_p0_acv_hard_memphy_umemphy_arriav_mem_phy_hphy_inst_6080.inst.<protected>.<protected> # Time: 17867500 # ERROR: Invalid arc in, fsm:AVL_FSM, state:AVL_IDLE # Instance: ddr2_example_sim.e0.if0.p0.ddr2_example_sim_e0_if0_p0_ddr2_example_sim_e0_if0_p0_acv_hard_memphy_umemphy_arriav_mem_phy_hphy_inst_6080.inst.<protected>.<protected> # Time: 17880000 Do you know what is this error? Thanks
