Cyclone V SoC Dev Kit PCIe End Port Example
I am trying to get the Cyclone V SoC Development Kit Board to behave as a PCIe End Port. I want to plug this board into a PCIe 4x slot on a PC motherboard running windows. This Dev Kit Board is really setup to be a root port and has a root port connector. So I can't plug the dev kit board directly into a slot on the motherboard. To solve this problem I purchased a male-to-male 4x adapter cable that also acts as a RX-to-TX crossover cable. A PCIe end port example design is included in the files I downloaded from Altera for the C5SoC dev kit. I had to make a few adjustments to the .qsf file, but I was able to get this end port example generated in qsys and compiled in quartus 13.1sp1. My problem is when I download the .sof into the dev kit fpga, the pc mother board doesn't seem to recognize it. I added a jtag master and a register to the design so I can read the PCIe LTSSM state bits. Using system console to read these bits, the PCIe controller appears to be going back and forth between the detect-quiet state and the polling-active state. My crossover adapter cable is fairly long (15"). I've ordered a shorter one (2") to see if this may be my problem. It will be a couple days before I get the 2" cable. In the mean time, I wanted to see if anyone else has tried to get the Cyclone V SoC Dev Kit Board to work as a PCIe End Port?
