13 years agoCyclone V SoC Dev Kit PCIe End Port Example
I am trying to get the Cyclone V SoC Development Kit Board to behave as a PCIe End Port. I want to plug this board into a PCIe 4x slot on a PC motherboard running windows. This Dev Kit Board is reall...
12 years agoHi Angad,
--- Quote Start --- I am testing the following design: http://rocketboards.org/foswiki/view/projects/pcierootportwithmsi If you Look into "Open Issue" - FB 165881 – Kernel can’t boot up if don’t have end point I have applied the patch that they are giving. It works fine on the Dev kit, But I tried the same patch for Other Cyclone V Device(5CSXFC6C6U23I7ES) The patch seems to fail. Basically from the patch I understood that the RootPort is being forced to complete the Enumeration But I dont understand why it wont work for other device other than Dev kit. --- Quote End --- That is a terrible issue - its like saying "Sorry, your PC cannot boot if you do not have a card in the PCIe slot"!!! Sorry, I've steered clear of the SoC devices for exactly this type of reason. I expected "teething" problems and didn't want to be the one to find them (been there, done that with earlier new generation devices). I didn't read any of the code. Perhaps there is just a "bad decision" in the RTL or in the bootloader code that is the cause of this issue. Cheers, Dave
