13 years agoCyclone V SoC Dev Kit PCIe End Port Example
I am trying to get the Cyclone V SoC Development Kit Board to behave as a PCIe End Port. I want to plug this board into a PCIe 4x slot on a PC motherboard running windows. This Dev Kit Board is reall...
12 years ago --- Quote Start --- Hi Angad, You mean you just want to see if the wires on the PCIe connector are working? If the root-complex is an FPGA, then sure, you can do whatever you like. For example, you can test a high-speed transceiver by configuring it in BIST mode and have it generate a PRBS pattern, or you can use a transceiver IP core and configure it manually and have it output a desired pattern. For example, a square wave at a low enough frequency that you can see it on a scope. You can also loop back the TX and RX differential signals using a PCIe breakout cable (Samtec sell them). http://www.samtec.com/technical-specifications/default.aspx?seriesmaster=pcrf I use this type of cable (the one with the peripheral style connector) as a way to access transceivers on kits that do not have HSMC or FMC connectors. Cheers, Dave --- Quote End --- Hi Dave, Thanks for the quick response. I am testing the following design: http://rocketboards.org/foswiki/view/projects/pcierootportwithmsi If you Look into "Open Issue" - FB 165881 – Kernel can’t boot up if don’t have end point I have applied the patch that they are giving. It works fine on the Dev kit, But I tried the same patch for Other Cyclone V Device(5CSXFC6C6U23I7ES) The patch seems to fail. Basically from the patch I understood that the RootPort is being forced to complete the Enumeration But I dont understand why it wont work for other device other than Dev kit. Regards Angad
