13 years agoCyclone V SoC Dev Kit PCIe End Port Example
I am trying to get the Cyclone V SoC Development Kit Board to behave as a PCIe End Port. I want to plug this board into a PCIe 4x slot on a PC motherboard running windows. This Dev Kit Board is reall...
11 years ago --- Quote Start --- Hello, I am also facing the same issue "Kernel hangs after 'Starting kernel' ". Can you please message the link for the patch? I coudn't find rp_rtl.zip file in cv_soc_rp_full_design.tar.gz or cv_soc_rp_simple_design.tar.gz(As per solution for FB 165881 – Kernel can’t boot up if don’t have end point). Regards Kushal --- Quote End --- Hi Kaushal, I am sure you would be using 13.1 or older version of Quartus. Use the latest version of Quartus 14.0 or higher. the issue has been addressed by Altera. For the higher version we do not require any patch hence Rocket boards have removed the patch from their site. Regards Angad
