14 years ago
Cyclone III configuration corrupts image
All,
We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like it should. But, on most of the boards, configuration with USBBlaster results no errors but a corrupt FPGA image in the chip. Multiple tries will usually result in one good configuration that allows us to program the EPCS. Once that is done the boards work reliably. Except that they are still as difficult to configure through JTAG as ever.
The problem varies from board to board. Some are good, some are not so good and others are completely useless. Most of the boards are flaky to useless.
All the voltages look good.
JTAG signals look clean.
The programming software generates no errors.
CONFIG_DONE goes high even though the image is bad. (We can tell by LEDs on the board if the image took or not.)
We've made Altera and Cyclone III boards before and have not had these kinds of problems.
What could possibly be causing this?
