14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years ago --- Quote Start --- INIT_DONE doesn't seem to work when programming via JTAG, but once the image is burned into EPCS, it does. --- Quote End --- I assume that you're not telling the tool you're using an external CLKUSR? (Just a suggestion) --- Quote Start --- So, the issue of the day is: what kind of problem would go away when we raise the voltage from 2.5 to 3.3? --- Quote End --- The only voltages you have at 2.5V are the VCCA/VCCD voltages right? Do these voltages even need to be powered for the device to exit power-on-reset? (Check the handbook). Try not powering them at all and see what happens. Cheers, Dave
