14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years agonCE was reworked from 300 to 10K, from "Cyclone II device family pin connection guidelines PCG-01003-1.1" - and using 10K actually makes it work a little better.
INIT_DONE is enabled. So is CRC. (note what I said earlier) Interestingly, INIT_DONE doesn't seem to work when programming via JTAG, but once the image is burned into EPCS, it does. How do I know the image is corrupt? 1. The CRC light is on. 2. LEDs that are supposed to be off are on. 3. We can't talk to the NIOS inside the chip. So, the issue of the day is: what kind of problem would go away when we raise the voltage from 2.5 to 3.3?
