12 years agoCPLD selection suggestion
We want to interface two devices (A and B) working at 148.5MHz. The first device (A) gives out data at the negative edge and the second device (B) captures at the positive edge. The clock to output delay of A varies from 1.64 to 5.3872ns. The minimum setup and hold times required at B are 1.3 and 0.8ns respectively. As per the timings, the ideal time for sampling the data will be at the negative edge. But as device B captures at the positive edge, the timings are not met when these two devices are connected directly. So, we want to interface these devices through a CPLD. The CPLD will capture the data from A at the negative edge and give out data to B at the rising edge. Can you please suggest me some suitable CPLD device that can be used for this purpose? Regards, Prachi
