12 years agoCPLD selection suggestion
Hi, We want to interface two devices (A and B) working at 148.5MHz. The first device (A) gives out data at the negative edge and the second device (B) captures at the positive edge. The cl...
12 years agoThanks for the update. I now better understand multi-cycle exceptions.
I played around with the code a bit. If I refactor 'B' into the clocked process in stead of using 'rb' TimeQuest says the design doesn't meet the timing. Anything fundamental I'm overlooking? We can eliminate the 'rb' register and directly assign 'B' from 'ra'. This may possibly allow using a smaller device. I also played around using a variable -> same results.
