VeeraJabil's avatar
VeeraJabil
2 months ago
Bent lead for PO 3014663251 JPN AX1822 5024
Problem   Lead bent  Incoming inspection   IQA  detected the issue.
 Qty 250 pcs incoming
All details attached for reference
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Hi Veera,
    I saw there is communication happening to proceed with the RMA for this.
    You should be contacted by your local FAE to continue the process.
    Aqid
  • VeeraJabil's avatar
    VeeraJabil
    Yes , follow your arrow is bent and yellow arrow sticker from bottom 3rd pin problem.
    AqidAyman_Altera
    We received your question. Can you help provide below clarification:
    May I know if the lower right unit (see purple arrow) has a bent lead on pin 1 dot?
