Asaf_Bloch's avatar
Asaf_Bloch
1 month ago
Cold Temperature Issue
Hallo,
We used the Agilex5 device in AS configuration connect to external QSPI Flash.
We apply Smart VID interface at the device demands.
When we perform Cold power up at -40C the device is not configured, It seemed the device is not  output from the POR, No traffic on the PMBus.
Power sequence and voltage ramp time and levels are OK.
Please advise
Asaf
  • dpcsu_e's avatar
    dpcsu_e
    just a short question (do not want to deter this thread): how did you detect it is not out of POR?
    (maybe relevant maybe not) On 2 out of 50 Agilex3 devices we have met with similar issue and resulted that over JTAG idcode was read as F36FF0DD instead of 4365B0DD. Is it equivalent to this same issue that SDM ROM code is not coming out of POR? do you observe similar behavior?
    How does your power topology looks like?
    We have 1.8V and 3.3V HVIO and if 3.3V HVIO's VCCIO do not get some minor accidental backfeed which raises it to 0.6V then FPGA stays in POR.
    Voltage rail sequence is 0.75V -> 1.8V -> 1.2V -> 3.3V.
    Is it ok to bring up 1.8V SDM and 1.8V VCCIO at the same time or should we bring up the 1.8V+3.3V VCCIO after 1.2V?
    Peter
    • Asaf_Bloch's avatar
      Asaf_Bloch
      Hi dpcsu,
      Thanks for your reply
      Our voltage rail sequence is VID, 08V -> 1.8V -> 1.2V, 3.3 VCCIO
      We detect the POR issue because we don't see any signal transitions after power up (nStatus, PMBus), JTAG detect the device.
      How did you read the SDM ROM?
        Any way we repeat the test with other PCB and it pass successfully, so we examine if it specific PCB issue.
      regards
      Asaf
      • Farabi_Altera's avatar
        Farabi_Altera
        Hello Asaf, Peter,
        Do you have update?
        regards,
        Farabi
    Farabi_Altera
    Can you share below information:
    1- QSPI flash part number
    2- VR(Voltage regulator) part number
    3- Agilex5 part number
    regards,
    Farabi
      Asaf_Bloch
      Hello Farabi,
      1 - QSPI Flash -  MT25QU256ABA8E12-1SIT by Micron
      2 - VR - LT7184SRV#TRPBF by Analog Device
      3 - Agilex5 - A5EC043AB23AI2E
      Asaf
        Farabi_Altera
        Hello Asaf,
        If the device is not output from POR, do you have the oscilloscope capture the power rails ramping up?
        Any abnormal voltage ramp up during power up? Especially all the power rails monitored by POR circuitry.
        regards,
        Farabi
