Cold Temperature Issue
- 2 months ago
Hi Asaf,
Good to hear that you solved the issue. Yes, all the configuration signals are sensitive can't let the voltage drop even few microseconds.
Can you share below information:
1- QSPI flash part number
2- VR(Voltage regulator) part number
3- Agilex5 part number
regards,
Farabi
- Asaf_Bloch3 months ago
Hello Farabi,
1 - QSPI Flash - MT25QU256ABA8E12-1SIT by Micron
2 - VR - LT7184SRV#TRPBF by Analog Device
3 - Agilex5 - A5EC043AB23AI2E
Asaf
- Farabi_Altera3 months ago
Hello Asaf,
If the device is not output from POR, do you have the oscilloscope capture the power rails ramping up?
Any abnormal voltage ramp up during power up? Especially all the power rails monitored by POR circuitry.
regards,
Farabi
Hello Farabi,
Thanks for your reply,
We checked Cold start up on other PCB and it pass successfully, so maybe it is assembly issue of specific PCB, we send it for examination and preheat of the FPGA and we will check it again.
See attached oscilloscope capture:
- Green - PMBus (3.3V), Red -VID voltage, Blue - 1.8V, Yellow - nConfig - it good power up, you can see transition on the PMBus.
- Red - VID, Yellow - nConfig, Green - SDM clock, Blue - Nstatus.
I don't see the SDM start the configuration prosses
Asaf
