13 years agoClock recovery from signle 125MHz pulses with PLL
I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity of data and clock recovery). From this data there are recovered 125 MHz pulses every 44.1 kHz (sync pulses). I would like to recover this 44.1 kHz clock from the bit stream. (for audio purposes - to match the clock of the data - if internal 44.1 clock is used form the generator there are some bad effects in the sound). My questions are: 1) Can i simply feed those pulses into the second PLL module to recover the data ? 2) Are there any other considerations that i should think about ? thanks madness123
