14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years agoYes you need to pay a license for it, or use it in evaluation mode (i.e. with the USB blaster connected all the time, and you can't flash your project)
