14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years ago --- Quote Start --- Yes you need to pay a license for it, or use it in evaluation mode (i.e. with the USB blaster connected all the time, and you can't flash your project) --- Quote End --- So as long as your USB-Blaster is connected, you can play with it. best regards
