14 years agoClock recovery from signle 125MHz pulses with PLL
Hi, I have a circuit that uses one PLL to recover data and clock from a single bitstream. This PLL is fed with 125 MHz clock, on it's output there is 375 MHz clock (which is used for the circuity ...
14 years agoThe core of an ADPLL would be a NCO generating the 176.4 kHz clock. Using a PI loop filter, it can ideally average the jitter of the sync signal to +/- 0.5 * 8ns, provided there's no additional jitter source than sampling the input signal at 125 MHz.
