17 years agoCIC Megacore
hi
i am tring to use the cic megacore from altera. but the core is just not running. i have made the following interface to it from my vhdl module:
component CIC port( clk : IN STD_LOGIC; clken : IN STD_LOGIC; reset_n : IN STD_LOGIC; in_data : IN STD_LOGIC_VECTOR (31 DOWNTO 0); in_valid : IN STD_LOGIC; out_ready : IN STD_LOGIC; in_error : IN STD_LOGIC_VECTOR (1 DOWNTO 0); out_data : OUT STD_LOGIC_VECTOR (31 DOWNTO 0); in_ready : OUT STD_LOGIC; out_valid : OUT STD_LOGIC; out_error : OUT STD_LOGIC_VECTOR (1 DOWNTO 0) ); end component; ---------------------------------------------------------------- ---------------------Read CIC---------------------------------- ---------------------------------------------------------------- process (nreset,clk) begin if nreset ='1' then out_ready<='0'; cic_out<="0000000000000000"; clken<='0'; elsif RISING_EDGE(clk) and out_valid ='1' then clken<='0'; cic_out<=out_data; out_ready<='1'; read_out_error<=out_error; else out_ready<='0'; out_ready<=out_ready; end if; end process; ---------------------------------------------------------------- ---------------------Write CIC---------------------------------- ---------------------------------------------------------------- process (nreset,clk) begin if nreset ='1' then in_valid<='0'; in_error<="00"; elsif RISING_EDGE(clk) and in_ready ='1' then in_valid<='1'; tempMIC8bit<="00001111";--MIC8bit; in_error<="00"; else in_valid<='0'; in_valid<=in_valid; end if; --in_valid<=in_valid; end process; U2:CIC PORT map (clk,clken,nreset,tempMIC8bit,in_valid,out_ready,in_error,out_data,in_ready,out_valid,out_error); the only thing thats working is "in_ready" that goes high when i hit the reset btn :(
why is it not working? do i have to include som ekstra files? quartus has already included alot of cic files for the component.
i am using the guide from altera:
http://www.altera.com/literature/ug/ug_cic.pdf
br
benjamin
Yes it worked :) Thanks allot!!!!!!
I ended up with this: U2:CIC PORT map (clk=>clk, clken=>'1', reset_n=>'1', in_data=>x"0F", in_valid=>'1', out_ready=>'1', in_error=>"00", out_data=>out_data, in_ready=>in_ready, out_valid=>out_valid, out_error=>out_error); BR Benjamin - Altera_Forum
All inputs should be connected and their logic identified. If it still doesn't work then you ned to check your core itself. clk=>clk, --ok clken=>'1', --ok reset_n=>reset_n, -- make sure this signal goes high for operation in_data=>x"0F", -- how is this accepted by compiler?? 8 to 32 bits in_valid=>in_valid, -- may be this => '1' will do for now out_ready=>out_ready, -- define this logic e.g. =>'1' in_error=>in_error, -- define this logic out_data=>out_data, in_ready=>in_ready, out_valid=>out_valid, out_error=>out_error kaz - Altera_Forum
Hi
I have changed the port mapping: U2:CIC PORT map (clk=>clk, clken=>'1', reset_n=>reset_n, in_data=>x"0F", in_valid=>in_valid, out_ready=>out_ready, in_error=>in_error, out_data=>out_data, in_ready=>in_ready, out_valid=>out_valid, out_error=>out_error); But there is still not happening anything - Altera_Forum
why not just remove the processes and do this: U1:CIC port map( clk => clk, clken => '1', reset_n => reset_n, in_data => x"0F0F0F0F", in_valid => '1', ...etc. kaz - Altera_Forum
You need some more work on your code. -you are driving clken low always. -reset is still not released - statements like in_valid<='0'; in_valid<=in_valid; doesn't look right to me as the signal is updated in the sequential process at compile time. I haven't use CIC core itself but many other cores and so can only help in general coding sense. Generally, with cores all you have to do is supply the right inputs to the core and connect the outputs. kaz - Altera_Forum
hi
i have now changed my code to this: ---------------------------------------------------------------- ---------------------Read CIC---------------------------------- ---------------------------------------------------------------- process (reset_n,clk) begin if reset_n ='1' then out_ready<='0'; cic_out<="0000000000000000"; clken<='0'; elsif RISING_EDGE(clk) and out_valid ='1' then clken<='0'; cic_out<=out_data; out_ready<='1'; read_out_error<=out_error; else out_ready<='0'; out_ready<=out_ready; end if; end process; ---------------------------------------------------------------- ---------------------Write CIC---------------------------------- ---------------------------------------------------------------- process (reset_n,clk) begin if reset_n ='1' then in_valid<='0'; in_error<="00"; elsif RISING_EDGE(clk) and in_ready ='1' then in_valid<='1'; tempMIC8bit<="00001111";--MIC8bit; in_error<="00"; else in_valid<='0'; in_valid<=in_valid; end if; --in_valid<=in_valid; end process; U2:CIC PORT map (clk,clken,reset_n,tempMIC8bit,in_valid,out_ready,in_error,out_data,in_ready,out_valid,out_error); sorry had it wrong, but i have just made the change a little time ago in desperate hunt for the solution to this problem. this should be better. but the cic ip is still not running. here is a picture of the signaltab: http://nygaard1899.dk/signaltap.bmp there is just not happening anything :(
br
benjamin
It is standard naming convention that reset_n is active negative i.e.
CIC is under reset when reset_n = '0' CIC is released for work when reset_n = '1' You may just invert your nreset then connect it to CIC(better change the name of nreset to reset) kaz - Altera_Forum
Hi
When I run my code nreset = 0, when I push the reset button on the board nreset = 1. It is inverted. Is CIC IP using a reset =1 to run? - Altera_Forum
But your two processes are using nReset as positive logic. This will clash with the CIC module
edit: also notice that statements like: in_valid<='0'; in_valid<=in_valid; is not quite meaningful as last statement overwrites and is final at compile time kaz - Altera_Forum
Yes, it is inverted. Don´t know how to invert the value on the btn on the board.
