17 years agoCIC Megacore
hi i am tring to use the cic megacore from altera. but the core is just not running. i have made the following interface to it from my vhdl module: component CIC port( clk : IN ST...
17 years agoIt is standard naming convention that reset_n is active negative i.e.
CIC is under reset when reset_n = '0' CIC is released for work when reset_n = '1' You may just invert your nreset then connect it to CIC(better change the name of nreset to reset) kaz
