17 years agoCIC Megacore
hi i am tring to use the cic megacore from altera. but the core is just not running. i have made the following interface to it from my vhdl module: component CIC port( clk : IN ST...
17 years agoHi,
You need some more work on your code. -you are driving clken low always. -reset is still not released - statements like in_valid<='0'; in_valid<=in_valid; doesn't look right to me as the signal is updated in the sequential process at compile time. I haven't use CIC core itself but many other cores and so can only help in general coding sense. Generally, with cores all you have to do is supply the right inputs to the core and connect the outputs. kaz
