17 years agoCIC Megacore
hi i am tring to use the cic megacore from altera. but the core is just not running. i have made the following interface to it from my vhdl module: component CIC port( clk : IN ST...
17 years agoHi,
All inputs should be connected and their logic identified. If it still doesn't work then you ned to check your core itself. clk=>clk, --ok clken=>'1', --ok reset_n=>reset_n, -- make sure this signal goes high for operation in_data=>x"0F", -- how is this accepted by compiler?? 8 to 32 bits in_valid=>in_valid, -- may be this => '1' will do for now out_ready=>out_ready, -- define this logic e.g. =>'1' in_error=>in_error, -- define this logic out_data=>out_data, in_ready=>in_ready, out_valid=>out_valid, out_error=>out_error kaz
