17 years agoCIC Megacore
hi i am tring to use the cic megacore from altera. but the core is just not running. i have made the following interface to it from my vhdl module: component CIC port( clk : IN ST...
17 years agohi
i have now changed my code to this: ---------------------------------------------------------------- ---------------------Read CIC---------------------------------- ---------------------------------------------------------------- process (reset_n,clk) begin if reset_n ='1' then out_ready<='0'; cic_out<="0000000000000000"; clken<='0'; elsif RISING_EDGE(clk) and out_valid ='1' then clken<='0'; cic_out<=out_data; out_ready<='1'; read_out_error<=out_error; else out_ready<='0'; out_ready<=out_ready; end if; end process; ---------------------------------------------------------------- ---------------------Write CIC---------------------------------- ---------------------------------------------------------------- process (reset_n,clk) begin if reset_n ='1' then in_valid<='0'; in_error<="00"; elsif RISING_EDGE(clk) and in_ready ='1' then in_valid<='1'; tempMIC8bit<="00001111";--MIC8bit; in_error<="00"; else in_valid<='0'; in_valid<=in_valid; end if; --in_valid<=in_valid; end process; U2:CIC PORT map (clk,clken,reset_n,tempMIC8bit,in_valid,out_ready,in_error,out_data,in_ready,out_valid,out_error); sorry had it wrong, but i have just made the change a little time ago in desperate hunt for the solution to this problem. this should be better. but the cic ip is still not running. here is a picture of the signaltab: http://nygaard1899.dk/signaltap.bmp there is just not happening anything :(
br
benjamin
