17 years ago
Altera MAX 3064 CPLD weird problem
I'm using Altera MAX3000 series (EPM3064-10 to be exact) with CPLD_CLK = 77.5Mhz, and I have a very weird problem...
pseudocode is below:
signal_abc = asynchronous from external chip
below is flip-flops (just pseudocode):
if (reset) then reset the flops
elsif (clk'event and clk = 1)
signal_abc_q1 <= signal_abc;
signal_abc_q2 <= signal_abc_q1;
signal_abc_q3 <= signal_abc_q2;
signal_abc_posedge <= signal_abc_q2 and not signal_abc_q3;
if (reset OR signal_def_clear = '1') then -- async reset
signal_def <= '0';
if (signal_abc_posedge = '1') then
signal_def <= '1';
But, I see intermittent problems where there is NO edge transitions of signal_abc (and clean), yet there is edge transition for signal_def.
tracing back:
- signal_abc stays low
- but (exporting signal_abc_q2 & q3 out to pads), I saw: these 2 internal flip-flops actually toggles from low to HIGH,
- which of course causes signal_abc_posedge to go HIGH,
- which causes signal_def to go HIGH
I can't figure out why this is happening... right now, the only thing I can think of is there's something wrong with the CPLD...
any help is greatly appreciated...
    If your timing analysis is successful then the main culprit is that your asynch signals have glitches from outside.
    You can apply a patch: design a basic test to ignore these glitches for example register the asynch signal or decide the edge only if it is more than one clk period or so.
    -- this code tests asynch signal being high at two successive clock edges
    -- Combinatorial logic for positive edge_to_pulse
    PROCESS (irq_src_reg_q2,irq_src_reg_q3, irq_src_reg_q4) IS
    BEGIN
    FOR i IN 0 TO 6 LOOP
         irq_src_reg_posedge(i) <= irq_src_reg_q2(i) and irq_src_reg_q3(i) and not irq_src_reg_q4(i);
    END LOOP;
    END PROCESS;
    btw, I only noticed these glitches when we changed our system clock to 77.5Mhz. when previously running at 51Mhz, I never encountered this issue...
    the loop there is to repeat the entire flops for the whole 7-bit arrays (including the clear register)...
    hmm... I can try to re-flop the posedge register...
    With regard to for loop in:
    interrupt_trigger: PROCESS (rst_n, clk, irq_clr_reg) IS
    BEGIN
    FOR i IN 0 to 6 LOOP
        IF (rst_n = '0' OR irq_clr_reg(i) = '1') THEN
           irq_trig_reg(i) <= '0';
        ELSIF (clk'EVENT AND clk = '1') THEN
              IF (irq_src_reg_posedge(i) = '1') THEN
                   irq_trig_reg(i) <= '1';
              END IF;
        END IF;
    END LOOP;
    END PROCESS interrupt_trigger
    Ia it possible that this may go wrong:
    why not put the loop start after clk edge, just a thought
    Sorry you are right you have indeed double registers(q2/q3). So I withdraw my first feel.
    Your code looks sound to me so far. The fact that the error is related to succession of asynch signal points to a possible glitch of irq_src_reg_posedge
    which is then registered as irq_trig_reg. It is now matter of speculations. But I will register the edge detection itself just in case.
    but this is to generate 1-clock-cycle wide of pulse when there's a rising-edge.
    I already made sure each bit went through double-flops before being used...
    For now I feel there is a problem here, this is combinatorial(unlike pseudocode)
    PROCESS (irq_src_reg_q2, irq_src_reg_q3) IS
    BEGIN
    irq_src_reg_posedge(i) <= irq_src_reg_q2(i) and not irq_src_reg_q3(i);
    END LOOP;
    END PROCESS;
    it will get you in trouble if there is any glitch
    sure, in the entity:
    irq_src_reg <= wlan_irq & NOT sdio_irq_n & NOT fb_n & sw_irq & NOT overcurr_n & headlift & NOT pb_n; -- these are external signals
    PROCESS (rst_n, clk) IS
    BEGIN
    IF (rst_n = '0') THEN
    irq_src_reg_q (6 downto 0) <= (OTHERS => '0');
    irq_src_reg_q2 (6 downto 0) <= (OTHERS => '0');
    irq_src_reg_q3 (6 downto 0) <= (OTHERS => '0');
    irq_n <= '1';
    ELSIF (clk'event and clk = '1') THEN
    irq_src_reg_q (6 downto 0) <= irq_src_reg (6 downto 0);
    irq_src_reg_q2 (6 downto 0) <= irq_src_reg_q (6 downto 0);
    irq_src_reg_q3 (6 downto 0) <= irq_src_reg_q2(6 downto 0);
    irq_n <= NOT (irq_trig_reg(6) OR irq_trig_reg(5) OR irq_trig_reg(4) OR irq_trig_reg(3) OR irq_trig_reg(2) OR irq_trig_reg(1) OR irq_trig_reg(0));
    END IF;
    END PROCESS;
    BEGIN
    END LOOP;
    END PROCESS;
    irq_clr_reg <= data(6 DOWNTO 0)
    WHEN (cs_n = '0' AND we_n = '0' AND addr = irq_clr_reg_addr)
    ELSE (OTHERS => '0')
    -- data is inout(7 downto 0) at top-level
    data <= 'Z' & irq_trig_reg
    WHEN ((cs_n = '0') AND (oe_n = '0') AND (addr = irq_trig_reg_addr))
    ELSE (OTHERS => 'Z')
    BEGIN
    END IF;
    END IF;
    END LOOP;
    In that case, you better post your main cpld code(not pseudocode) so that we can share it all. (not the project please)
    But, this only happens intermittently even after I turned OFF the "power-up dont care"...
    after a few hundreds transitions of signal_abc, then I will see this error...
    small amount of transitions are alright...
    I don't expect max devices to go wrong on a basic drive.
    Are you sure you start up with these flips on zero. I assume you do reset them to zero but there is an option of power-up don't care and it defaults to ON. quartus is then free to choose low or high logic for power up. You must change this default to No
