17 years agoAltera MAX 3064 CPLD weird problem
Hi, I'm using Altera MAX3000 series (EPM3064-10 to be exact) with CPLD_CLK = 77.5Mhz, and I have a very weird problem... pseudocode is below: signal_abc = asynchronous from external c...
17 years agosure, in the entity:
irq_src_reg <= wlan_irq & NOT sdio_irq_n & NOT fb_n & sw_irq & NOT overcurr_n & headlift & NOT pb_n; -- these are external signals PROCESS (rst_n, clk) IS BEGIN IF (rst_n = '0') THEN irq_src_reg_q (6 downto 0) <= (OTHERS => '0'); irq_src_reg_q2 (6 downto 0) <= (OTHERS => '0'); irq_src_reg_q3 (6 downto 0) <= (OTHERS => '0'); irq_n <= '1'; ELSIF (clk'event and clk = '1') THEN irq_src_reg_q (6 downto 0) <= irq_src_reg (6 downto 0); irq_src_reg_q2 (6 downto 0) <= irq_src_reg_q (6 downto 0); irq_src_reg_q3 (6 downto 0) <= irq_src_reg_q2(6 downto 0); irq_n <= NOT (irq_trig_reg(6) OR irq_trig_reg(5) OR irq_trig_reg(4) OR irq_trig_reg(3) OR irq_trig_reg(2) OR irq_trig_reg(1) OR irq_trig_reg(0)); END IF; END PROCESS; -- Combinatorial logic for positive edge_to_pulse PROCESS (irq_src_reg_q2, irq_src_reg_q3) IS BEGIN FOR i IN 0 TO 6 LOOP irq_src_reg_posedge(i) <= irq_src_reg_q2(i) and not irq_src_reg_q3(i); END LOOP; END PROCESS; irq_clr_reg <= data(6 DOWNTO 0) WHEN (cs_n = '0' AND we_n = '0' AND addr = irq_clr_reg_addr) ELSE (OTHERS => '0') -- data is inout(7 downto 0) at top-level data <= 'Z' & irq_trig_reg WHEN ((cs_n = '0') AND (oe_n = '0') AND (addr = irq_trig_reg_addr)) ELSE (OTHERS => 'Z') interrupt_trigger: PROCESS (rst_n, clk, irq_clr_reg) IS BEGIN FOR i IN 0 to 6 LOOP IF (rst_n = '0' OR irq_clr_reg(i) = '1') THEN irq_trig_reg(i) <= '0'; ELSIF (clk'EVENT AND clk = '1') THEN IF (irq_src_reg_posedge(i) = '1') THEN irq_trig_reg(i) <= '1'; END IF; END IF; END LOOP; END PROCESS interrupt_trigger
