ALT_LVDS timing fails for core clock
I'm using Quartus 13.1 with a Stratix IV GX dev kit. Trying to implement a simple test design for a 6 bit deserialiser using ALT_LVDS Rx. But I'm getting timing errors in a weird place. The register at the outputs of the LVDS_Rx megafunction. The slow clock. Timequest says the launch clock is the dast clock (480MHz). The latch clock is the slow clock (80MHz). And there are hold errors. I don't see why these exist. Is there something wrong with the way I am reading them? Its a simple design. 8 channels Lvds Rx with 6 bit deserialiser. Slow speeds. Feeds to a DC FIFO.. But I can't meet timing according to quartus.. Attached a couple of screenshots if it helps. Thanks ZubairLK https://www.alteraforum.com/forum/attachment.php?attachmentid=8454 https://www.alteraforum.com/forum/attachment.php?attachmentid=845521 Replies
Are you saying the serial clock in is 480MHz, serial out is 80MHz then you have dc fifo on 80MHz write side and 480MHz read side? are your clock connections correct. Can you give a short description of your over all design and its clocking scheme.
I am only receiving data from the LVDS_Rx megafunction
ADC sending 12 bit serialized data at 480Mbps. Clock at 480Mhz as well. I intend to use 6 bit SERDES. And will mux the data later to form 12 bits. 8 channels of serialized data goes into the LVDS_Rx megafunction. 6 bit deserializer 480Mhz clk input the clk_output from the LVDS_Rx megafunction is 80MHz and goes into the write clock of a DC FIFO. The deserialized data output from the LVDS Megafunction goes into the data input of the DC FIFO. Timing fails at this point. The data output from the LVDS_Rx megafunction. I don't know why. For some reason, timequest says the LVDS_Rx megafunction deserialized data 'output' is clocked at the fast clock (480MHz). and is being latched at the slow clock (80MHz) on the DC FIFO side. Hope this explains ZubairLK - Altera_Forum
So you got two issues. clock wiring reported is wrong and timing fails. weird indeed.
have you you entered sdc file just in case. - Altera_Forum
I believe there is a multicycle from the slow to the fast domain. Try adding "derive_pll_clocks" to your .sdc, as I think that will add it.
I do have an sdc. Define the clock inputs. Set the input delay based on setup and hold times.
And have derive pll clocks in it too. I'll paste it tomorrow morning from the lab.. But its a simple constraints. Took it from the DDR cookbook from the wiki. I was wondering if giving LVDS megafunction the fast bitclk as clock input would be better or giving it the slow frameclock is better.. And if that makes it quirky.. Hope this helps. ZubairLK - Altera_Forum
--- Quote Start --- I do have an sdc. Define the clock inputs. Set the input delay based on setup and hold times. And have derive pll clocks in it too. I'll paste it tomorrow morning from the lab.. But its a simple constraints. Took it from the DDR cookbook from the wiki. I was wondering if giving LVDS megafunction the fast bitclk as clock input would be better or giving it the slow frameclock is better.. And if that makes it quirky.. Hope this helps. ZubairLK --- Quote End --- if you have option of registered output on rx lvds then that must be checked. It could be they are not registered and data path is from from bitclk to fifo - Altera_Forum
I tried that. Same kind of error. Launch clock fast clock at 480Mhz. And latch clock 160MHz..
--- Quote Start --- I tried that. Same kind of error. Launch clock fast clock at 480Mhz. And latch clock 160MHz.. --- Quote End --- look at the rtl viewer to see why that path is so. I expect there is no register at outputof lvds - Altera_Forum
--- Quote Start --- look at the rtl viewer to see why that path is so. I expect there is no register at outputof lvds --- Quote End --- Its there.. I notice the multicycle for setup is 6 and multicycle for hold is 5. These are done by the megafunction. Should the hold multicycle be 6 too? Here is a screenshot with the RTL.. https://www.alteraforum.com/forum/attachment.php?attachmentid=8457 - Altera_Forum
I can see the register clocked by rx_outclk so the reported path does not exist. Clearly wrong reporting unless fitter removes it which I doubt.
hold multicycle must always be 1 less than setup multicycle (for all source sync cases) as this says the launch/latch edges are those aligned with zero relationship so 5 is ok.
