12 years agoALT_LVDS timing fails for core clock
Hi, I'm using Quartus 13.1 with a Stratix IV GX dev kit. Trying to implement a simple test design for a 6 bit deserialiser using ALT_LVDS Rx. But I'm getting timing errors in a weird pla...
12 years agoI am only receiving data from the LVDS_Rx megafunction
ADC sending 12 bit serialized data at 480Mbps. Clock at 480Mhz as well. I intend to use 6 bit SERDES. And will mux the data later to form 12 bits. 8 channels of serialized data goes into the LVDS_Rx megafunction. 6 bit deserializer 480Mhz clk input the clk_output from the LVDS_Rx megafunction is 80MHz and goes into the write clock of a DC FIFO. The deserialized data output from the LVDS Megafunction goes into the data input of the DC FIFO. Timing fails at this point. The data output from the LVDS_Rx megafunction. I don't know why. For some reason, timequest says the LVDS_Rx megafunction deserialized data 'output' is clocked at the fast clock (480MHz). and is being latched at the slow clock (80MHz) on the DC FIFO side. Hope this explains ZubairLK
