12 years agoALT_LVDS timing fails for core clock
Hi, I'm using Quartus 13.1 with a Stratix IV GX dev kit. Trying to implement a simple test design for a 6 bit deserialiser using ALT_LVDS Rx. But I'm getting timing errors in a weird pla...
12 years agoAre you saying the serial clock in is 480MHz, serial out is 80MHz then you have dc fifo on 80MHz write side and 480MHz read side? are your clock connections correct. Can you give a short description of your over all design and its clocking scheme.
