Agilex7i devkit - device not support reconfiguration with factory SDM helper image
i'm using DK-DEV-AGI027RBES devkit, The board switches are configured as follows, trying to refresh the Agilex7i *.jic file using my design with hps. A while ago i flashed a golden reference *jic via an embedded jtag (J8) and see yocto boot. The same ghrd *.jic reprogramming is blocked by some devices in the JTAG chain. Can you provide steps on how to reprogram *.jic/ghrd *.jic?
SW1=ON/Off/Off/Off;
SW2=ON/Off/Off/Off;
SW3=Off/ON/ON/Off;
SW4=Off/Off/ON/Off;
SW5=Off/Off/Off/Off;
SW8=Off/Off/Off/Off
NOTE: I tried flashing the GHRD *.JIC using the devkit embedded USB blaster and I saw the same popup and stopped me from loading the JIC.
Also, although *.sof is being programmed, "Error (20064): Error status: Unable to set chip select" always appears. What does it mean? Why am I getting this error?
Shivaji M
- Jeet14
Please refer the below link for running the HPS example design on this development kit. This link will help on the board step and .pof & .jic flashing.
Tiwari
- shivajim
Thanks for the link, I tried the same. For some reason it didn't allow reflashing after first time flashing the images, but after changing the switch settings I was able to re-program. also I observed that if the uboot merged *.jic's were flushed to the Agilex, then sdm got stuck on the bootloop, u-boot fails to load image from qspi, then falls back and continues after wdt timeout. I also found the same popup when I tried to erase fpash/re-pogram golden *.jic in this situation, changing the switch helped to load golden *.jic.
Shivaji M
- GeorgeAndrawos
Same here, I switched temporarily to jtag msel to flash the jic then it worked.
