Agilex7i devkit - device not support reconfiguration with factory SDM helper image
Please refer the below link for running the HPS example design on this development kit. This link will help on the board step and .pof & .jic flashing.
Tiwari
- shivajim2 years ago
Thanks for the link, I tried the same. For some reason it didn't allow reflashing after first time flashing the images, but after changing the switch settings I was able to re-program. also I observed that if the uboot merged *.jic's were flushed to the Agilex, then sdm got stuck on the bootloop, u-boot fails to load image from qspi, then falls back and continues after wdt timeout. I also found the same popup when I tried to erase fpash/re-pogram golden *.jic in this situation, changing the switch helped to load golden *.jic.
Shivaji M
- GeorgeAndrawos1 year ago
Same here, I switched temporarily to jtag msel to flash the jic then it worked.
- FvM1 year ago
JTAG configuration, also .jic programming, basically works with all MSEL settings. There might be however a problem if MSEL is set to AS configuration and flash memory holds no valid configuration. FPGA configuration controller may perform endless tries to load the configuration, interfering with two-step .jic programming. Need to disable FPGA configuration controller in programmer options.
