shivajim
2 years agoAgilex7i devkit - device not support reconfiguration with factory SDM helper image
Hi, i'm using DK-DEV-AGI027RBES devkit, The board switches are configured as follows, trying to refresh the Agilex7i *.jic file using my design with hps. A while ago i flashed a golden reference *ji...
shivajim
2 years agoHi,
Thanks for the link, I tried the same. For some reason it didn't allow reflashing after first time flashing the images, but after changing the switch settings I was able to re-program. also I observed that if the uboot merged *.jic's were flushed to the Agilex, then sdm got stuck on the bootloop, u-boot fails to load image from qspi, then falls back and continues after wdt timeout. I also found the same popup when I tried to erase fpash/re-pogram golden *.jic in this situation, changing the switch helped to load golden *.jic.
Shivaji M
GeorgeAndrawos
1 year agoSame here, I switched temporarily to jtag msel to flash the jic then it worked.
- FvM1 year ago
JTAG configuration, also .jic programming, basically works with all MSEL settings. There might be however a problem if MSEL is set to AS configuration and flash memory holds no valid configuration. FPGA configuration controller may perform endless tries to load the configuration, interfering with two-step .jic programming. Need to disable FPGA configuration controller in programmer options.
