JET60200's avatar
JET60200
5 years ago
A10 PCIe HIP "nreset_status" signal tobe deasserted randomly, even though npor&pin_pers remains high
hello expert,
We uses Arria10 PCIe HIP core to build a EP device. In general, the FPGA works fine when plugging inside x86 SERVER PCIE Slot at most cases .
But for a part of x86 servers, we found A10 PCIe HIP “"nreset_status"” signal will be deasserted sometimes and randomly, while at that moment PCIe HIP's " npor & pin_pers " signals keep at High. According to " ug-01145_avmm-1_0.pdf " description, "
apps_rstn, which is derived from npor
or pin_perstn.
Thus one word to say , in our exceptional case, eventhough either "npor" or " pin_perstn " keeps to "high", " apps_rstn " still be deasserted to LOW (0). I want to find why it happens ?
Appreciate any helps.
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    KhaiY
    KhaiChein_Y_Intel
    Does the transceiver calibration successful? Can you check if the pin_perst of the Hard IP instance connects to the corresponding nPERST pin of the device correctly? Could you share the signal tap result?
    These pins have the following locations:
    • NPERSTL0: bottom left Hard IP and CvP blocks
    • NPERSTL1: top left Hard IP block
    • NPERSTR0: bottom right Hard IP block
    • NPERSTR1: top right Hard IP block
    KhaiY
    KhaiChein_Y_Intel
    Could you share the signaltap with signals below? What is the speed grade and lane number used?
    pll_cal_busy
    tx_cal_busy[n-1:0]
    rx_cal_busy[n-1:0]
    pin_perst
    npor
    reset_status
    pld_clk_inuse
    pll_locked
    rx_is_lockedtoref[n-1:0]
    rx_is_lockedtodata[n-1:0]
    rx_std_signaldetect[n-1:0]
    ltssmstate[4:0]
    lane_act[3:0]
    currentspeed[1:0]
    rx_ready[n-1:0]
    tx_ready[n-1:0]
    rx_analogreset[n-1:0]
    rx_digitalreset[n-1:0]
    tx_analogreset[n-1:0]
    tx_digitalreset[n-1:0]
    tx_st*
    rx_st*
    KhaiY
    • JET60200's avatar
      JET60200
      Thanks @KhaiChein_Y_Intel for reply,
      We checked PCIe HIP part library code, and found below code. To my understanding, this "output reset_status" signal dedrived from "reset_status_hip" signal, while the "reset_status_hip" comes from :
      twentynm_hssi_gen3_x8_pcie_hip { .reset_status (reset_status_hip), } ;
      My puzzle is : what does this "hssi_gen3_x8_pcie_hip { .reset_status )" stand for ?
      At what condition, this "hssi_gen3_x8_pcie_hip { .reset_status )" would be deasserted ?
      ThankS a lot !!
      ;; \qpro19_2_ip\board_pcie_a10_hip_0\altera_pcie_a10_hip_191\synth\altpcie_a10_hip_pipen1b.v
      wire reset_status_hip;
      output reset_status,
      twentynm_hssi_gen3_x8_pcie_hip # (
      <params ...>
      ) wys (
      .reset_status (reset_status_hip), // where does the [ reset_status_hip] come from ??
      // synthesis translate_on
      .wake_oen (wakeoen )
      altpcie_sc_bitsync_node #(
      ) reset_status_altpcie_sc_bitsync(
      .clk (pld_clk) ,// clock
      .rst_n (npor_sync) ,// async reset
      .data_in (reset_status_hip) ,// data in
      .data_out (reset_status) // data out
