A10 PCIe HIP "nreset_status" signal tobe deasserted randomly, even though npor&pin_pers remains high
Could you share the signaltap with signals below? What is the speed grade and lane number used?
pll_cal_busy
tx_cal_busy[n-1:0]
rx_cal_busy[n-1:0]
pin_perst
npor
reset_status
pld_clk_inuse
pll_locked
rx_is_lockedtoref[n-1:0]
rx_is_lockedtodata[n-1:0]
rx_std_signaldetect[n-1:0]
ltssmstate[4:0]
lane_act[3:0]
currentspeed[1:0]
rx_ready[n-1:0]
tx_ready[n-1:0]
rx_analogreset[n-1:0]
rx_digitalreset[n-1:0]
tx_analogreset[n-1:0]
tx_digitalreset[n-1:0]
tx_st*
rx_st*
KhaiY
- JET602005 years ago
Contributor
Thanks @KhaiChein_Y_Intel for reply,
We checked PCIe HIP part library code, and found below code. To my understanding, this "output reset_status" signal dedrived from "reset_status_hip" signal, while the "reset_status_hip" comes from :
twentynm_hssi_gen3_x8_pcie_hip { .reset_status (reset_status_hip), } ;
My puzzle is : what does this "hssi_gen3_x8_pcie_hip { .reset_status )" stand for ?
At what condition, this "hssi_gen3_x8_pcie_hip { .reset_status )" would be deasserted ?
ThankS a lot !!
;; \qpro19_2_ip\board_pcie_a10_hip_0\altera_pcie_a10_hip_191\synth\altpcie_a10_hip_pipen1b.vwire reset_status_hip;output reset_status,twentynm_hssi_gen3_x8_pcie_hip # (<params ...>) wys (....reset_status (reset_status_hip), // where does the [ reset_status_hip] come from ??...// synthesis translate_on.wake_oen (wakeoen ));altpcie_sc_bitsync_node #() reset_status_altpcie_sc_bitsync(.clk (pld_clk) ,// clock.rst_n (npor_sync) ,// async reset.data_in (reset_status_hip) ,// data in.data_out (reset_status) // data out);]
