JET60200
Contributor
5 years agoA10 PCIe HIP "nreset_status" signal tobe deasserted randomly, even though npor&pin_pers remains high
hello expert,
We uses Arria10 PCIe HIP core to build a EP device. In general, the FPGA works fine when plugging inside x86 SERVER PCIE Slot at most cases .
But for a part of x86 servers, we f...
KhaiChein_Y_Intel
5 years agoHi,
Does the transceiver calibration successful? Can you check if the pin_perst of the Hard IP instance connects to the corresponding nPERST pin of the device correctly? Could you share the signal tap result?
These pins have the following locations:
• NPERSTL0: bottom left Hard IP and CvP blocks
• NPERSTL1: top left Hard IP block
• NPERSTR0: bottom right Hard IP block
• NPERSTR1: top right Hard IP block
KhaiY
