Anonymous's avatar
Anonymous
Not applicable
3 years ago
Verilog Coding
I am getting the following error
[Synth 8-403] loop limit (65536) exceeded
Could somebody please help, the design code is as below:
module latchregister_4bit(
input clk, reset,
input in,
output reg pulse,
output [3:0]out);
parameter DUTY = 50; // in percentage
parameter clk_pd = 10;
parameter clk_on = (DUTY * clk_pd) / 100;
parameter clk_off = (100 - DUTY) * clk_pd / 100;
reg start_clk;
// Initialize variables to zero
initial
begin
start_clk <= 0;
pulse <= 0;
end
always@(posedge clk or negedge clk) begin
if(clk)
start_clk = 1;
else
start_clk = 0;
end
// Achieve duty cycle by a skewed clock on/off
// run as long as the clocks are turned on.
always@(posedge start_clk) begin
if (start_clk) begin
pulse = 1;
while (start_clk) begin
#(clk_on) pulse = 0;
#(clk_off) pulse = 1;
end
pulse = 0;
end
end
reg [3:0]q;
always@(pulse)
begin
if(reset)
q<=4'b0000;
else if(pulse)
q<={in,q[3:1]};
end
assign out = q;
endmodule
  • _AK6DN_'s avatar
    _AK6DN_
    Getting an error from what tool? Quartus? Modelsim? Or what?
    Are you trying to just simulate some verilog code or trying to compile/synthesize for a device? If so, what device?
    FYI your code may be legal verilog syntax so a simulator may accept it, but it is not synthesizeable verilog.
    Structures like this:
    pulse = 1;
        end
    pulse = 0;
    are not valid synthesis structures.
  • FvM's avatar
    FvM
    you have written a potentially endless loop statement. Basically it's a misunderstanding about the purpose of loop statements in synthesized Verilog. They are used to generate parallel logic rather than a sequence in time.
  • ShengN_altera's avatar
    ShengN_altera
    end
    This part causes the loop doesn't have any way to exit, it becomes an infinite loop that the synthesis tool cannot handle. May be you can use a counter to count the number of clock cycles for the on and off periods to achieve the duty cycle you're looking for.
    Sheng
