omer_be's avatar
omer_be
4 months ago
DK-DEV-AGI027RES Install Package
i'm looking for the BTS for this board:
DK-DEV-AGI027RES
its look that what we have on the altera site its for newer version of the board and the BTS not working.
can someone share the install package for this board
thank you
omer.
  • omer_be's avatar
    omer_be
    thank,
    can you also send the package because the BTS still not working.
    • FakhrulA_altera's avatar
      FakhrulA_altera
      Let me send you another file. Please convert the .txt to .zip in order to use the file.
      Fakhrul
        FakhrulA_altera
        Hi Omer,
        I will close this thread as I have already shared the file with you via message. Let’s continue our communication there.
    FakhrulA_altera
    Hi Omer_be,
    Apologies for the delay in sending the file. I’ve converted it to .txt format since the system doesn’t allow .qsf attachments. You may change the extension of the file from .txt to .qsf before use it.
    Please find the file below.
    Fakhrul
    • TorsteinH's avatar
      TorsteinH
      Do you have the factory recovery POF file for the MAX 10 BMC on the same board?
      Thanks, Torstein
