NYup's avatar
NYup
7 years ago
enable secure JTAG in max10 lockup board.
Error (209014): CONFIG DONE is FAILED to go high
What is the problem?
I am using Quartus version 18.0 on linux.
FPGA MAX10 device number 10M08SAM156CBG
I enable Secure JTAG with Intel provided Internal JTAG block
with UNLOCK/LOCK ports out to I/O.
I pulled on UNLOCK port HIGH, send in UNLOCK JTAG COMMAND
via quartus_jli
[nyup@labOptiPlex2 test_unlock]$ quartus_jli -c 2 unlock_208.jam -a unlock
Info: *******************************************************************
Info: Running Quartus Prime Jam Tools
Info: Version 18.0.0 Build 614 04/24/2018 SJ Standard Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Fri Sep 20 14:33:36 2019
Info: Command: quartus_jli -c 2 unlock_208.jam -a unlock
Info: Using INI file /opt/intelFPGA/18.0/quartus/linux64/quartus.ini
Exit code = 0... Success
Info: Quartus Prime Jam Tools was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 194 megabytes
Info: Processing ended: Fri Sep 20 14:33:39 2019
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:00
'Altera 2016
'Purpose: To unlock
ACTION unlock = DO_UNLOCK;
PROCEDURE DO_UNLOCK;
DRSTOP IDLE;
IRSTOP IDLE;
STATE IDLE;
IRSCAN 10, $208;
WAIT 100 USEC;
EXIT 0;
ENDPROC;
I tried with $041; too
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Hi Nhu,
    I believe this is the duplicated case of 04351475. I will continue to support your request in this case 04351475.
    Thank You.
    • NYup's avatar
      NYup
      The indicator isn’t accessible on our system board . I will ask Bert our local FAE whose evaluation board is locked up to see what it is . Thanks Nhu-Ha
    • NYup's avatar
      NYup
      What does the checkbox for jtag enable do ? Does the WUSIWUG control the config_done pin? I got 3 boards locked up and bought a couple more evaluations board. But I don’t want to lock them up again . Nhu-Ha
    • NYup's avatar
      NYup
      Yes I did run the Lock_Unlock_complete signal to an LED indicator. It turns on, indicating complete, not sure what is complete With the light on, the programmer lets me try to send a file (either POF or SOF) but fails When the light is off the programmer detects no device and doesn’t let me set up a file to be programmed, it just assumes there is no FPGA present. I have sent the QAR file for my design to IPS, not sure what they will do with it as they need the specific HW board. Nhu-Ha Yup Rajant Corporation 4505 E. Chandler Blvd. #250 Phoenix, AZ 85048 [email protected] <[email protected]> P: 602-362-2150 x2216
    YuanLi_S_Intel
    Hi Nhu-Ha Yup,
    Sorry for the late, WYSIWYG is an internal JTAG interface. It doesn't control CONF_DONE pin directly but if the configuration is working successfully, the CONF_DONE pin will be asserted.
    Just would like to check, have you used our reference design and also the JAM file provided? Or you use your own and obtain the following error? Please let me know.
    Just for your information, you can obtain the reference design at link below:
    https://fpgacloud.intel.com/devstore/platform/15.0.0/Standard/max10-jtag-secure-unlock/
    The steps to use the reference design is in this AN556:
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an556.pdf
    Thank You.
    • NYup's avatar
      NYup
      It doesn’t work. I also refer to that document . My board is locked up . I can’t erase or reload anything. Please tell me how to unlock the board Nhu-Ha
    • NYup's avatar
      NYup
      Will you send me your QAR for your max10 evaluation board ? I can try it on my max 10 evaluation board . Please tell me how you pulse unlock command. Nhu-Ha
    • NYup's avatar
      NYup
      Hello, You said your board is working with secure Jtag. I asked you last week if you will send me the QAR for your max 10 board. I have not heard back from you. It will help me alot since I have been stuck for months now. Nhu-Ha Yup Rajant Corporation 4505 E. Chandler Blvd. #250 Phoenix, AZ 85048 [email protected] <[email protected]> P: 602-362-2150 x2216
    YuanLi_S_Intel
    Hi Nhu-ha,
    I have just tested on my side, seems like no problem in locking and unlocking. Just would like to check, how do you unlock the MAX10? From the above statement, seems like u were running the command to unlock. If it so, can you try to provide a pulse only to UNLOCK pin? With the unlock pulse, the JTAG will be changed from internal JTAG mode to external JTAG mode and thus you can do programming and erasing using JTAG. No command is needed to unlock.
    Also, speaking about the design, once you program the POF file obtained from the reference design available at link below:
    The device will change into JTAG secure mode once the device is powered on.
    Thank You.
    • NYup's avatar
      NYup
      We power down and the next day the board is locked up . I will ask Robert Polk our FAE to answer tell you what he did since he locked up the evaluation board w just your secure jtag design Nhu-Ha
    YuanLi_S_Intel
    Hi Nhu-Ha Yup,
    Any update from FAE? For your information, just send a pulse to UNLOCK pin (Assert to HIGH then deassert to LOW), the board will unlock.
    Thank You.
