NYup
7 years agoenable secure JTAG in max10 lockup board.
Error (209014): CONFIG DONE is FAILED to go high What is the problem? I am using Quartus version 18.0 on linux. FPGA MAX10 device number 10M08SAM156CBG I enable Secure JTAG with Intel provided In...
YuanLi_S_Intel
6 years agoHi Nhu,
This is weird. By right it should be able to program after you UNLOCK it. May i know, have you observed if "indicator" port is going HIGH? You may also refer to the steps to UNLOCK as shown at link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf (Page 58)
Thank You.
- NYup6 years ago
The indicator isn’t accessible on our system board . I will ask Bert our local FAE whose evaluation board is locked up to see what it is . Thanks Nhu-Ha - NYup6 years ago
What does the checkbox for jtag enable do ? Does the WUSIWUG control the config_done pin? I got 3 boards locked up and bought a couple more evaluations board. But I don’t want to lock them up again . Nhu-Ha - NYup6 years ago
Yes I did run the Lock_Unlock_complete signal to an LED indicator. It turns on, indicating complete, not sure what is complete With the light on, the programmer lets me try to send a file (either POF or SOF) but fails When the light is off the programmer detects no device and doesn’t let me set up a file to be programmed, it just assumes there is no FPGA present. I have sent the QAR file for my design to IPS, not sure what they will do with it as they need the specific HW board. Nhu-Ha Yup Rajant Corporation 4505 E. Chandler Blvd. #250 Phoenix, AZ 85048 [email protected] <[email protected]> P: 602-362-2150 x2216 - NYup6 years ago
any suggestion how to unlock the board. I have not heard anything for a long time Nhu-Ha Yup Rajant Corporation 4505 E. Chandler Blvd. #250 Phoenix, AZ 85048 [email protected] <[email protected]> P: 602-362-2150 x2216
