Derek_yeepixel_ASAP's avatar
Derek_yeepixel_ASAP
2 months ago
Design of MAX V CPLD 5M2210 System Controller in Arria 10 SoC board
Hi Altera,
  Could you help to share the MAX V CPLD 5M2210 System Controller with me? We're in AI research work with Arria 10 SoC board and need the source code of system maxV but is not included in the installer package, arria10_10as066n3f40_soc_v15.1.2.zip.
Thank you!
  • Hi Aqid,
     I downloaded it again with your link, which show me the same message as below, you can read it from
    arria10_10as066n3f40_soc_v15.1.2\examples\max5\PRD\system_max5\read me.txt as well.
    "Currently the source code of system maxV is not included in the installer package, please file a SR to require for it if you are interested."
    • AqidAyman_Altera's avatar
      AqidAyman_Altera
      Hi Derek,
      Yes, I understand. I just need your confirmation that I am referring to the same development kit as you.
      For the source file to be shared, you will need to file ticket through Altera Premier Support (APS). If you do not have the access, contact for your local authorized distributor so they can help to file an APS ticket on your behalf.
      Let me know if this is not possible.
      Aqid
  • Thanks for your suggestion, keep you posted with the ticket number with LAD support soon.
      AqidAyman_Altera
      Thanks, let me know the APS ticket number once you have it.
      AqidAyman_Altera
      Hi Derek,
      I check the ticket and it is already be assigned to the right expert.
      The file is expected to be provided through the APS ticket.
      Aqid
