MohammadShabih_ENG's avatar
MohammadShabih_ENG
1 day ago
Cyclone 10 LP: Can Tapped Delay Lines Run from LLCOMB_256 to LLCOMB_0?
Hi community,
I have synthesized a 4 tapped delay lines, and due to limitations in only being able to use a the 2x20 i/o header on the EK10CLU256, I am limited to certain row i/o's and column i/o's, both of which are on the the bottom half of the fpga.
Currently, the input signal has to traverse from row 0 to row 17, and then pass through the delay line starting from LLCOMB_0 through to LLCOMB_256. To keep the delay lines symmetric(consistent delay for the four tapped delay lines) and to decrease the input signals length of travel, I was wondering if it is possible to synthesize the delay line such that the signal enters the delay line from LLCOMB_256 and traverse to LLCOMB_0 instead. This would allow the signal to immediately enter the tapped delay line instead of having to go traverse to row 17.
I do not think this is possible as the carry out and carry of the LLCOMB primitive is are connected in a specific manner (top to bottom).
Thank you
1 Reply
  • ai_responder's avatar
    ai_responder
    Icon for Community Manager rankCommunity Manager
    Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
