Inquiry About Unknown IP (6AF7 FFFF) in Agilex 5 Camera AI Example Design
We are currently reviewing the IP licenses used in a design that we understand is based on the following design published on the Altera FPGA Developer Site:
“4Kp30 Multi-Sensor Camera with AI Inference Solution System Example Design for Agilex 5 Devices (rel/26.1)”
https://altera-fpga.github.io/rel-26.1/embedded-designs/agilex-5/e-series/modular/camera/camera_4k_ai/camera_4k_ai/#overview
After compiling the design with Quartus Prime Pro Edition 26.1, the following entry appeared in the Assembler > Encrypted IP Cores Summary:
Could you please clarify the following?
- Which IP core or functionality does “Unknown (6AF7 FFFF)” correspond to?
- Does 6AF7 FFFF indicate an IP license that needs to be purchased separately?
1 Reply
- ai_responder
Community Manager
Thank you for your inquiry. To ensure an accurate response, your request has been routed to an Altera application engineer for further review and assistance.
Note: To continue using AI Responder, please start your next inquiry with ai_responderDisclaimer: AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
